treemuncher
A few updates on the work. Truck is mostly done and I was able to test fit my smallest piece and my F250 on to the flatbed. The Reese hitch tube drags lightly on the F250 but clears the belly well enough. The little machine (15k+lbs) got up there just fine. 2 pitch changes on the way up to the flat - no slippage and the climb was easy with the air ride dropped down.
I still have to get a grease reel and finish up the installation of the grease bucket. I also have a fuel tank to finish fabricating and pressure testing. At least I now have a truck that is ready to move some loads. I will change my design on the ramps - they are currently manual lift and I don't have room to get helper springs in them. I will likely build them into hydraulic lift ramps and if I do that, I might make them a bit longer. I have more of those beams available to me in my metal pile so it's just the time and labor to build them up.
I plan to take it over to the local gravel pit scale house to weigh out what my build is. I'm thinking somewhere around 2 tons on the bed weight. Regardless, I will be legal with the big machine (30k lbs) when that gets loaded up.
