Condenser
Discussion in 'Agricultural Equipment' started by Old Doug, Aug 11, 2017.
  1. Old Doug
    Old Doug Senior Member
    Oct 16, 2013
    592
    Mo
    I never saw one go bad until the last few years. I have replaced 2 on a guys 70 F600 and a buddys 3010 wouldnt start i told him to replace it that fixed it but a year or so later he called and said it wouldnt start it was the condenser agin.Is their something else goting on?
  2. Moonlite
    Moonlite Senior Member
    Nov 12, 2013
    394
    Texas
    If it's not burning up the points I would say it's just defective condensers.
  3. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    1,277
    Grass Valley, Ca
    Maybe because there are hardly any left running still, they are not doing quality control any longer. Just a thought.
  4. DIYDAVE
    DIYDAVE Senior Member
    Feb 18, 2007
    435
    MD
    I've been replacing point and condenser units, with pertronix electronic ignition kits. Its about $100, same labor as p&C, and generally fixes it forever....
    colson04, Tenwheeler and mikebramel like this.
  5. colson04
    colson04 Well-Known Member
    Apr 11, 2016
    102
    Delton, Michigan
    +1 on the pertronix electronic ignition kit. Simple to install and basically maintenance free. I 've used them on Volkswagen engines used in sandrails. They work very well and can take handle the abuse of hard trail or dune riding all day. Don't use off brand electronic ignition kits though. They quickly become more work than points. Pertronix is the name to trust.
  6. farmerlund
    farmerlund Well-Known Member
    Nov 23, 2014
    234
    Farmer/ excavator
    North Dakota
    Yep, no reason to stick with the points setup. switch it and be done. plus they run better and don't need adjustment.
  7. Old Doug
    Oct 16, 2013
    592
    Mo
    I have used alot of stuff with points and other than haveing to change or clean them on something that i bought or has been seting i cant complane.I read about the pertronix but one thing i didnt see is will the same system work on 4 6 and v8s?
  8. DIYDAVE
    Feb 18, 2007
    435
    MD
    Basically its broken down into voltage and grounding. 12 + or - ground and 6 volt + or - ground. needs a coil with 3 ohms resistance, too. PM me and I'll give you the name of a company, that sells them, at a good price...;)
