Chaining down Excavator Properly
Discussion in 'Equipment Moving Questions' started by gabelmatt, Dec 1, 2009.
  1. gabelmatt
    gabelmatt Active Member
    May 1, 2009
    35
    Mini Excavator Owner/Operator
    Ontario
    Hey Guys, I live in Ontario and I have 5 tonn mini excavator and I was wondering if anyone else in Ontario has one and what is the proper way of chaining it down. I just have a tandom trailer that i pull behind my pick-up.Any input would be great.
    Thanks
  2. adv.wastewater
    adv.wastewater Well-Known Member
    Oct 25, 2009
    64
    Blount County Alabama
    You have the excavator I want! I am waiting until next spring to buy mine though. I have a 7,500 lb machine now. Anyways, I run a chain over the blade and under the arms that connect the blade to the machine than back over the blade to my trailer. (kind of worded confusing) than on the oposite end of the machine of the blade my machine has a chaining eye that I run a chain through. Not sure if the 305 has that. If not you can lay your boom down and put a chain over your bucket. You want to endup with a chain holding the machine from going forward, and a chain holding the machine from coming back. And when the chains are tight obviously they will prevent the machine from going sideways. How do you like your machine so far? What size bucket are you using and what do you mainly use it for?
  3. heavylift
    heavylift Senior Member
    Sep 5, 2009
    1,046
    KS
    it should have labels on it... green with a hook...
    most of the time when it moved around on big plant jobs... it's one chain across the blade...
    But DOT likes enough chains and boomers that it outweighs the load your hauling..
  4. gabelmatt
    May 1, 2009
    35
    Ontario
    I love the new machine.Just got it back yesturday from Cat, they were putting my new hyd. pin grabber on it.I have a 62" ditching bucket,24" tooth a 16" tooth and a 48" hyd tilt bucket for it. Mainly I use it for utility trenching. The odd drive way, I have a post hole auger for it too so I get the odd job for it too.
  5. insleyboy
    insleyboy Well-Known Member
    Jun 25, 2008
    191
    Operator 25 years, was laborer for 7 years
    Monroe Michigan
    Mdot requires a chain (seperate chain mind you) on each corner of a machine. Plus one on each implament. So on a mini that is 6. The 4 corners, with a seperate binder. Then one on the blade and one on the bucket. I got a 300 dollar ticket few years ago for only 4 chains on a case 580 backhoe. Each US State has different interpretations, so you may want to check Ontario law gabelmatt.
  6. -NICK-
    -NICK- Well-Known Member
    Mar 21, 2009
    180
    Driver
    california
    Well not quite a excavator but Ive been chaining down like this for a while now.Keep hearing a about chp dot not wanting or allowing chains on tracks and I have got enough tickets in the last few years for stuff that I had to fight.So this seems to be the way to make everybody happy.
  7. -NICK-
    Mar 21, 2009
    180
    Driver
    california
  8. dporter
    dporter Active Member
    Jan 16, 2010
    31
    landscape, project manager
    midland, ontario
    In Ontario the laws state under 10,000 lbs only 2 chains are required. however an additional chain is required for every 10 feet in excess of 10 feet. Also a separate chain is required for every attachment.
    One chain to rear, one on front and the bucket must be placed on the deck and be chained separately.
  9. Vantage_TeS
    Vantage_TeS Senior Member
    May 29, 2008
    495
    HE Operator. Surprise?
    Calgary, Alberta
    Well that's sort of silly, the load of the chain is still applied to the track chaining like that. If the hook could bend or rip a pad off then so could the side pressure on that chain!
    But as we all know trying to tell THEM that is about the same as this: :Banghead
  10. Corona Kid
    Corona Kid Member
    Sep 2, 2009
    12
    Henderson, Nevada
    I got checked by the Boys at the NB 15 Cajon scales with a Volvo EC460 on the 7 , 2 15k Binders on each corner (to the track pads) 1 across the stick . "looks Good, Have a Nice Day"
  11. -NICK-
    Mar 21, 2009
    180
    Driver
    california
    Its just too bad they all can't agree on what makes them happy.:beatsme
  12. Corona Kid
    Corona Kid Member
    Sep 2, 2009
    12
    Henderson, Nevada
    Yeah...Different Scale=Different Rules :Banghead
  13. norite
    norite Senior Member
    Aug 1, 2010
    483
    Sudbury, Ontario, Canada
    I have seen lots of big excavators cross chained front and rear from the pads down to the deck, wouldn't work too well for a rubber tracked mini-x though.
    I like the way Nick does it, seems to be superior to depending on the pad bolts which have had their heads skidded over rock etc, or even the pad itself which may have a crack in it and is ready to break off.
  14. bigbob
    bigbob Well-Known Member
    Dec 19, 2007
    184
    Lee,NH
    I have 3 excavators, a 311 CU, 307, and just bough a 305C CR. I quizzed the cat salesman on how to chain down the 305. Cat has a sticker on the front of the machine explaining how to do it. It is not in compliance with the DOT's rules, I have been pulled over 7 times concerning chaining equipment down. The last time I laid into the officer verbally, have not been pulled over since.
    Getting back to the 305. Cat recommends chaining to the ends of the blade and to the hole in the center frame. This does not meet DOT standards since you are chaining to an implement. You cannot chain to a rubber track and I also disagree about chaining to a steel track pad. It is not what I consider the Frame.
    BTW, I asked the cat salesman to find out about how to chain down the 305 so it meets DOT standards. He still has not gotten back to me!
  15. cummins05
    cummins05 Senior Member
    Jan 4, 2009
    430
    Edmonton
    I would imagine the Cat salesman does not want the liability of telling you how to chain down your load to DOT standards.
    What I did was took a picture of my truck with two skid steer loader's and one small mini ex on the trailer.
    Took that to the weigh scale and asked them to write out how by the book how to secure every machine bucket sweeper shovel and broom on the unit.
    To my surprise they did might work for you.
    I also saved myself a ticket turns out the spread on the unit was to close and I had to rent a longer trailer to run into BC
  16. SONIC
    SONIC Member
    Nov 11, 2010
    5
    minnesota
    chaining down heavy machinery
    do you have any other photos of chaining down an excavator
  17. Deeretime
    Deeretime Senior Member
    Sep 12, 2009
    344
    superintendent
    High River Alberta
    Phone your local scale and they will provide you with a sheet showing how and where they want stuff tied down. Here are some things that I have learned in alberta
    All chains and straps must have a load rating of 25% or more of the machine or unit you are tieing down. if not you have to add more tie downs. Chains and boomers must have a load rating Tag at all times
    if it is 500lbs or over 4m long it requires 2 straps
    if the machine articulates each end must be cross chained on 4 corrners + any G.E.T's (buckets rippers blades) The only exception is if it is equiped with a manual articulation lock
    if your machine is 5 T or less the boom doesnt need to be tied down
    Cannot carry attachments in the machines bucket or the box of a gravel truck
    This one is retarded I spent 10hrs at a scale in edmonton for this ! old style snap boomers must have a manual lock to hold them closed... if not you get stuck like me so dont be cheap buy rachet boomers
  18. SONIC
    SONIC Member
    Nov 11, 2010
    5
    minnesota
    i just like tos ee some photos do you know where i can get some so how to ?
  19. Deeretime
    Sep 12, 2009
    344
    superintendent
    High River Alberta
    yup I took some of these a while ago to put into our manual. (weather you guys agree or not it is my company's interpretation of our transport specks!)
  20. Deeretime
    Sep 12, 2009
    344
    superintendent
    High River Alberta
