CaT IT14G Slow Hydraulic Lift Speed
marka683
Chicago
Mechanic
Bucket takes about 25 seconds to reach full lift height, main line hydraulic pressure is 3500 PSI, the unit just started lifting slow one day, all drive and steering functions seem good. ZN00519 any ideas?
Thanks
Mark250
victoria,Australia
heavy equipment technician
it is a simple system with the front section of a two section gear pump suppling the implement circuit. it is possible that the pump has a problem or that the pump inlet oil is restricted in some way
are there any noises like marbles in the pump or does the oil appear aerated or milky. here is the pump performance guide to check the pump
you could also have low pilot pressure going to the main control valve to operate the lift spool. to check that, you would either have to remove the batteries to gain access to the test port on the transmission pump which supplies pilot oil or put a tee into the pilot line that controls the lift function. should be about 430 psi at idle and about 460 at high idle
another cause could be leaking seals in the lift cylinders you could isolate each cylinder in turn and see if that makes a difference
len.mccluskey
United States
Technical Writer
Check the pump. Is the pump inlet oil restricted or is it making any noise? What is the texture of the oil?
The test Mark205 send is very useful, keep us in touch about your findings!
