Greetings all,
I have a Cat 977H (1963) that has been gradually having issues with both forward/reverse in that it seems to slip when under load - worse when machine is cold. Checked oil levels/quality, checked filter - guessing this is a 'wet clutch' setup. Oil is not burned, no fragments of clutch packs in filter ... someone told us some of these 977's have an external pump, others internal - appears this is internal. (They said it sounded like there's air being introduced somewhere into the hydraulics of the transmission). Once machine is warmed up sufficiently and can roll - it steers well; not sure if the two are related.
Thanks in advance - hope not to scrap this machine as it runs very well otherwise - does not burn oil, tracks/sprockets still have 60-70% life left - there's no way I could afford a trans rebuild - would be cheaper to scrap it and find a 955 for what I need to do - the 977's overkill for my work.
Larry
Larry
