Themaskman72
Here's a couple of my chargers I'm using.View attachment 164891 View attachment 164891 View attachment 164892
Not sure what the problem is with the videos, both come up after a time saying Error.
Here's a couple short videos to update you guys on where I am with the 955L right now, thanks.
At some point you are going to have to at least pull the engine head. If the hood is already off it is not that big of a job, might as well get those wrenches out and get started. I would first remove the glow plugs and spin the engine to get a clue as to if it is one cylinder or all of them. You can also fab up threaded pluming to screw into the glow plug holes and put about 100 lbs air pressure on the cylinders, one at a time, to see where the water comes out. You might also drain the oil and leave the plug out to see if the water goes to the oil pan. CAUTION, remove the radiator cap before putting air into the cylinders. Just my 2 cents worth.
