Cat 941
Discussion in 'Track Loaders' started by egnsean, Dec 19, 2007.
  1. egnsean
    egnsean Member
    Dec 18, 2007
    11
    uk
    any one have any photos of CAT 941, i worked for a company called Buctons
    LTD from Oldham Lancashire they always used 941s for road formation work
    with very experenced operators on them they could work to half an inch and
    the formation was nearly ready for tarmac when they had finished they could
    put the crown & camber on the road faster than any other machine as i say
    the operators were very experienced and mostly Irish, they were a pleasure
    to watch:notworthy
  2. NateV
    NateV Well-Known Member
    Nov 22, 2004
    157
    Excavating
    Pittsburgh PA
    Only one i have of ours
      File size:
      36.3 KB
      4,401
  3. digger242j
    digger242j Administrator
    Oct 31, 2003
    5,888
    Self employed excavator
    Southwestern PA
    Here's one I spent many an hour on. The people that owned it bought it used in about 1983, and kept it for almost 20 years. If I recall correctly, it was built in 1960-something. The CAT sticker on the side says 941B, but that was put on when it was painted. It wasn't a B, just a plain old 941.
    It was traded in, and I thought I'd seen the last of it. A year or so later, I was on my way to look at a job 30 miles away, and there, in a field beside the road, she was. Fresh mud is in the tracks, so she was still apparently earning her keep. The third picture is of a repair I had done to the bucket. It was finally wearing right through the sides there at the bottom.
    You can't really tell from the pictures, but we believed it may have had a hoe mounted to it at one time. You can see a threaded rod at the rear of the machine, just inside the track, and a grab handle where it's not really of any use, (unless you were climbing up to operate a hoe). It also had some extraneous plumbing that was removed at some point, and the ROPS had the very back part of the roof (between the curved part of the ROPS frame), cut away, as if it had been needed for operator headroom.
  4. NateV
    Nov 22, 2004
    157
    Excavating
    Pittsburgh PA
    It seems to me like these old track loaders (highlifts) still get a lot of use in the western pa area.
  5. TALLRICK
    TALLRICK Well-Known Member
    Apr 28, 2007
    195
    florida
    Around here, they have gone the way of the dinosaur. Believe it or not, I miss them, and would enjoy operating one from time to time. Too bad that seems impossible now.
  6. bobcat ron
    bobcat ron Banned
    Nov 25, 2007
    843
    playing with the new 247 MTL
    Abbistan, B.C.
    Those track loaders are the reason my Dad got started in the excavation biz in '84.
  7. NateV
    Nov 22, 2004
    157
    Excavating
    Pittsburgh PA
    Yeah same with when my dads uncles started in it that was all he used for everything. Thats what my dad first learned on, and what i like to run as well. For as little of time iv been playing around with this stuff, i really do like the track loader.
  8. will_gurt
    will_gurt Charter Member
    Nov 30, 2003
    163
    operator in extended holding pattern
    southwestern ,PA
    Digger, you are bringing back memories for me.... This particular machine is a 1969 model. If memory serves me correct, it was able to wear out all the normal items as well as an engine. What job were these photos taken on Digger?
  9. digger242j
    Oct 31, 2003
    5,888
    Southwestern PA
    Someplace out in the country, the year after it was traded away.
    I don't know that it "wore out" an engine exactly, as much as it just decided one day to eat a valve. (If I recall correctly.)
    You'd be particularly well qualified to comment on the job of keeping the brakes in adjustment, wouldn't you, Will?
  10. will_gurt
    Nov 30, 2003
    163
    southwestern ,PA
    Yes you can say that! Can do them in my sleep, so to speak.... As for the engine crapping out. One thing led to another and then the "well... while you're in there" syndrome took over....
  11. Z24O
    Z24O Well-Known Member
    Sep 28, 2007
    79
    Tasmania
    here is the 941 i am in the process of buying
    i want to fit a 4in1 bucket which i have sourced but have been told it will be a very expensive job as i will need all the controls,cat lines and swivels
    i was wondering why you couldn't use a T valve from the ripper controls and flexible/steel lines made to measure
    anyone know if the cab pictured would provide any protection in a fall on/over situation
    sorry to hijack the thread
  12. onecleverdude
    onecleverdude New Member
    Dec 3, 2007
    3
    heavy equipment mechanic
    Wisconsin
    hey all.
    I bought a 941 about seven years back. it had a burned valve seat. cost me a whole hundred bucks to fix the motor.
    ran very strong. looked like hell. had an enclosed cab.
    diesel was cheap, and we must have moved some 5000 yards of dirt out back to level a hill.
    my twins were just toddlers back then. they always wanted a ride in the cat.
    the vibration and noise would put them right to sleep.
    very tough old machines. 3304 motors. easy and cheap to rebuild. lots of aftermarket parts out there for cat.....
  13. honest outlaw
    honest outlaw Active Member
    Feb 22, 2008
    42
    general contractor
    chesnee south carolina
    better a 41 than a 51 as i've been told by a cat salesman years ago. a 51 was just a 41 with a bigger bucket and a turned up injector pump. the 51 my grandfather had stayed tore up more than it ran.:Banghead:beatsme:notworthy
  14. Countryboy
    Countryboy Senior Member
    Jun 8, 2006
    3,276
    Load Out Tech. / Heavy Equipment Operator / Locomo
    Georgia
    Welcome to Heavy Equipment Forums honest outlaw! :drinkup
  15. honest outlaw
    Feb 22, 2008
    42
    general contractor
    thanks country boy i've searched the net before for a dirtman forum glad i finally found one.:):D:notworthy:notworthy:drinkup:usa:cool: from all my perusing through seems to be a fine forum!!!:)::bash:notworthy
  16. bundysgn
    bundysgn Member
    Mar 15, 2008
    13
    grantsville, md
    when my uncle retired from his excavation company he owned 2 941
  17. lillyroger
    lillyroger Member
    Dec 25, 2008
    10
    south australia
    We still run an 941 80h1309 serial number
  18. Johnny English
    Johnny English Well-Known Member
    Jan 2, 2009
    113
    Contracts manager, Civil Engineering contractor
    Lincolnshire, UK
    Hi guys, we still run a 1972 941B with a 4 in 1 bucket and a Leverton cab as opposed to a Bowmaker. We run laser gear on it and everything, it'll still complete with any GPS or laser guided dozer for grade and will still push hard next to a 953.
  19. t_dirt
    t_dirt Well-Known Member
    Oct 31, 2008
    49
    Birmingham, AL
  20. RIrwin
    RIrwin Member
    Jan 22, 2009
    6
    Southern IL
    Anyone ever rebuild a 3304 engine in a 941B themselves? Just wondering how big of a job it would be.
