I have a 1997 924 f with a 6YX05446 transmission, that I can't get to go into gear. I am the 4th or 5th person to work on this machine, and was told that one of the people that worked on it, hot wired and got it to move to it's current spot. I have been working on the assumption that it was an electrical problem, and finally found the hot wire for the ecm hooked to the fuse for the lights on the machine, which was blown. Still the only power that I have going into the shifter is for the backup alarm, which works if the key is on or not. I decided to see what the psi was on the transmission valve body, so I pulled the p1 fitting out, and had no fluid at all coming out, I then pulled the p3 fitting out and also had no fluid coming out. I have no manual for this machine but have found a few things on line that has helped me get to the point that I am at now, but I can't seem to find anything on if there is a bypass solenoid or some other reason that I am getting no fluid thru the valve body, or is the torque converter or pump out. I do have fluid traveling to the filter, although I didn't put a gauge to it, just broke the line loose to see if I had flow. Any advice on where to look would be appreciated. Mike
