Cat backhoe 420E. Serial number C4E06212. PIN: CAT0420EVPRA00699.
Problem: When using joystick to tilt bucket forward, without warning, the bucket tilts all way forward, rapidly, and joystick loses control. When bucket stops, fully tilted forward, joystick will not work to tilt bucket back. To regain joystick function there is a short "lever-like" device on right side of backhoe, in front of cab, outside engine side-panel sheet metal. With bucket malfunction this "lever" is moved forward from its normal position. I take a block of wood, place on front surface of "lever", hit wood block with big hammer and "lever" moves back(toward windshield) to correct position, then joystick works again.
I cannot determine function of the external "lever" and need to learn how to correct problem. Besides aggravation. uncontrolled forward bucket tilt is safety issue. Joystick often has a "catch" in it when moving bucket so I am suspecting there is a connection to bucket tilt problem.
I am a farmer, hoping to find help to fix problem and avoid having to load, transport and pay Cat dealer for repair.
Thanks for any help anyone can provide.
David
David
