Cat 416C, how do I change control pattern?
Discussion in 'Tractor/Loader/Backhoes' started by rutwad, Oct 14, 2009.
  1. rutwad
    rutwad Well-Known Member
    May 13, 2007
    244
    My father bought a Cat 416C and it is set up with excavator style controls. He wants to change the controls to (right- dipper/bucket, left-boom/swing). I have searched the net and found that some have a valve that can be changed. I can't find this valve. Could someone post a pic?
    Without a valve, how would we change the controls?
    If it helps the serial # is 4zn????? (if I remember correctly).
    THANKS!!!
  2. Mackcat
    Mackcat Active Member
    Oct 18, 2008
    25
    North Carolina
    If it has a valve it would be under the left fender behind a cover plate
  3. rutwad
    May 13, 2007
    244
    Without the valve what's the next best option, Changing hoses at the controls?
  4. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,430
    Service Manager
    Knoxville TN
    I don't know that you can do that. I'm not experienced with the 416C compononents, but many machines like this use individual circuit reliefs in the valve sections for each function. If yours does, it's likely the circuit relief pressure for the swing is lower than the relief pressure for, say, bucket curl. If you simply switch hoses between bucket curl and swing, you would now have high pressure relief on the swing. Not sure about this, just thought I'd mention it. ;)
  5. rutwad
    May 13, 2007
    244
    What about the dipper and boom? Do you think they would be set to similiar pressure? That's the 2 that he would change.
  6. willie59
    Dec 21, 2008
    11,430
    Service Manager
    Knoxville TN
    I really don't know. Call your local Cat dealer and ask them for the pressure settings for the hoe functions. That would tell you what you need to know.
  7. John C.
    John C. Senior Member
    Jun 12, 2007
    3,574
    Equipment Mechanic
    A 416C is a linkage machine so you have to buy some parts and change some of the linkages.
    As stated above, call your dealer and I think there is a kit.
  8. willie59
    Dec 21, 2008
    11,430
    Service Manager
    Knoxville TN
    I was thinking that John C. It seems I remember reading a thread some time ago about a likage kit to change the controls, was thinking it was Cat 416, just wasn't sure enough to mention it. A linkage kit would be cool. :)
  9. LonestarCobra
    LonestarCobra Well-Known Member
    Sep 4, 2008
    227
    WV
    Cat has a control linkage kit for pretty much all patterns. They have the JD 2-Stick pattern, 4-stick Ford, 3-stick Case with foot swing, and the Excavator pattern. All are easy to install, but they cost more than one would think. When the "D" series came out, they made it easy to change with the valve.
  10. heavylift
    heavylift Senior Member
    Sep 5, 2009
    1,046
    KS
    I know they change them because i worked for a company that had some 416's with a excavator pattern on them.... don't know what was changed...
    I would think it would be a matter of switching hoses... komatsu excavators had a colored coded hose change chart....
    I can jump back and forth when there on the right machine.... rubber tire pattern on a rubber tire is fine... x not so good... excavator with cat pattern fine.... r/t pattern is ok, just takes about an hour or so to get used to it again.
    I agree with give cat a call
  11. willie59
    Dec 21, 2008
    11,430
    Service Manager
    Knoxville TN
    Slow down there heavylift, excavators are different than loader/hoes. :) I've switched those color coded connections on Komatsu EX75's as you described. And some of the Cat ex's had a similar setup, with colored hose connections, prior to the models that have the selector valve. But when you "switch" these hoses, your switching the pilot lines that work the control valves. That's different than switching the hoses that come from the control valve to the cylinders. A linkage kit would be ideal, as the hose connections would remain proper. But, if it's more expensive than rutwad can afford, he may be able to switch hoses for boom and stick at the control valves, the relief pressure may be comparable, I can't say for sure. A call to Cat dealer could confirm this. ;)
  12. heavylift
    Sep 5, 2009
    1,046
    KS
    Dang it ...and I already had a wrench out :)
    I know most people like the cheaper route :) I did say to call cat....:)
    I know they're changeable just don't know what they changed.
    The field mechanic wouldn't do it... about a hour later a move truck picked it up, drop off a 580. Then brought the 416 back a couple days later.
  13. gradin
    gradin New Member
    Nov 8, 2009
    1
    operating backhoe and dozer
    boston
    Cat 416 B controls boom & stick
    Hello out there..I recently purchased a 1994 Cat 416B the boom and stick are opposite from the cat 416's and excavator's at my real job...it appears someone has changed them at some point.I gave it a quick peek and at least it does not look like any lines have been changed or out of place could this be a linkage deal.The swing and bucket are the same configuration...it is only the boom and stick that I want to change back to the original configuration.Its a real pain running all week cat controls then switching on weekend for side jobs.
    Would appreciate your expertise or direction here before I go to cat dealer.
    Thankyou
  14. DCH
    DCH Member
    Jun 2, 2009
    24
    BC, Canada
    for the 416C, take off the housing around the control levers, remove all the linkages and replace them with 2 straight threaded rods. I welded 2 bolts with the correct thread together to make it work, the machine is made to have backhoe controls and there is a mess of linkages in there to make it work excavator controls. It's an easy fix.
    Here is a picture of my fix.
    [​IMG]
