Hi Gents,
Thanks for support… the job done and the excavator working fine.
I tried to start the engine before replacing the injectors… the fuel rail pressure was 3485 PSI But I couldn't start the engine
I tried by force duo to spray gasoline from Air filter ,the result of delivered fuel volume mm3 cutout test was (26.0 ,25.9 ,25.8 ,25.6 ,25.5 mm3 )... The problem I found after removing the Injectors the trimming files is not matching with the injectors …. I asked the owner of Excavator how changed the injectors last time?
He said one of my friend ,but it wasn't want to start ,I contacted with dealer and he came to program the injectors.
Gents.... actually the dealer guy fooled the owner that he change the trim files but no, he was Indian guy and he is lazy ... With the new Injectors working perfect and cutout test result just for reference the delivered fuel volume mm3 (22.8, 22.7, 22.7 ,22.5, 22.3 , 22.2 mm3).
Do you think guys 2 mm3 and the injectors needle was dirty with black scales it makes different.
Thanks a lot.
