Cat 3208 engine in HPSI unit
Discussion in 'Generators/Gensets' started by Frankhaddad, Aug 30, 2017.
  1. Frankhaddad
    Frankhaddad Member
    Aug 25, 2017
    5
    Maine
    Not a lot of info to go by, other than it is an older 3208 cat engine, n/a. Fuel leak coming from throttle shaft, driven by air cylinder, not a lot of clearance. Is it possible to change the seal without removing the injection pump? Any advise would be great! Thank you.
  2. Tenwheeler
    Tenwheeler Well-Known Member
    Dec 16, 2016
    80
    Georgia
    As best I recall the pump has to come apart in order to replace that seal. Normally a job for a pump shop.
  3. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    2,286
    Master IP rebuilder
    Sunny South Carolina
    The throttle shaft is a 1 pc unit, the only way to replace the seal is to remove the governor.. its a simple task IF you have the room.. about 8-10 bolts & its off.. BUT clearance may be a problem..
    Tenwheeler likes this.
  4. Frankhaddad
    Frankhaddad Member
    Aug 25, 2017
    5
    Maine
    About to make the repair soon, will update when complete. Thank you.
  5. crane operator
    crane operator Senior Member
    Mar 27, 2009
    1,321
    sw missouri
    I had to do the throttle shaft seal on a 3208, and I think we had to pull the fuel line assembly's to get the access to pull the cover.
