Cat 3204
Discussion in 'Wheel Loaders' started by Boots, Mar 6, 2008.
  1. Boots
    Boots Active Member
    Feb 24, 2008
    44
    Colorado
    We got a Cat 916 that has the Cat 3204 engine and it is rated at 86 hp turbocharged, the 926 has the 3204 and it is rated at 105, I was wondering if anyone had any information on what the differerence is? Is the pump turned up? is it a different pump? All the specs on the 2 machines seem to be the same except for the hp. Thanks
  2. Squizzy246B
    Squizzy246B Administrator
    Sep 9, 2005
    3,388
    Digger Driver
    Perth, Western Australia
    Boots, your stretching my memory...but the pump is totally recalibrated, different injectors and I'm pretty sure the cooling system capacity was increased. I hardly touched the 3204's but unlike the different versions of the 3208, 3408 etc the changes were not too dramatic....better ask an expert cause I have something in the back of my mind about timing on the fuel pump...or was it the fuel pump cam.....delivery valves..Hmmmm:beatsme
    How old is the 916 and 926?. I ask cause the older 3204 had the pre-combustion (indirect injection) and you couldn't really turn them up....well too much anyway
  3. Boots
    Boots Active Member
    Feb 24, 2008
    44
    Colorado
    It is a 1987 model. Seems like it is a newer generation, but I'm new to Cat machines.
    Australia? hope to get there someday, beautiful country. Reading this forum with posts from all over the world, it seems that heavy equipment and Cat are universal languages.
  4. Squizzy246B
    Sep 9, 2005
    3,388
    Digger Driver
    Should be a DI engine then but its best to get a Cat dealer to run the serial number to give you some data and any history.
  5. 68jbo
    68jbo New Member
    Jul 21, 2008
    1
    virginia
    cat 3204 engine
    Hi,
    I am thinking of buying a D3 Cat with a bad engine. It has a Cat 3204 engine. My question is are all 3204 the same meaning will they all bolt up? How hard are they to come by used?
    Thanks
  6. Countryboy
    Countryboy Senior Member
    Jun 8, 2006
    3,276
    Load Out Tech. / Heavy Equipment Operator / Locomo
    Georgia
    Welcome to Heavy Equipment Forums 68jbo! :drinkup
  7. QUANIE
    QUANIE Member
    Jan 18, 2008
    16
    NASSAU
    My experence with the 3204 is that they do not hold out well , most of the used machines with them have some kind of engine problem, . I believe cat do not make them any more. and a good running one is hard to find .
  8. Komatsu 150
    Komatsu 150 Senior Member
    Aug 18, 2007
    664
    Northern Illinois
    I just want to disagree a little. I think the 3204 turbo with the higher horsepower ratings have a real poor history. The natural aspirated low horsepower did real well. Our 943 went 15000 hours plus before overhaul. It used a certain amount of oil from day 1 and only increased oil used at the end. It didn't break, just needed overhaul.
  9. QUANIE
    QUANIE Member
    Jan 18, 2008
    16
    NASSAU
    :eek: I gess your experence was better than mine , I had Three D3s and all went down with engine problems, not for lack of service .
  10. Komatsu 150
    Aug 18, 2007
    664
    Northern Illinois
    Actually I was worried about that engine from the time we bought the machine especially since they had a two ring piston. We had terrible service from 3208s and I was expecting problems. We did change bearings around 9000 hours when they pulled the engine to change the hydraulic pump. Other than 1 set of injectors and seals, a waterpump that was about it. There were a few other 943s in town and it seems that they did pretty well with the engine. Many 953's with the turbo and I think none of them went even five or six thousand hours.
  11. z656
    z656 Member
    Dec 7, 2007
    15
    ohio
    Anybody no block heater location 916 3204 engine
  12. Komatsu 150
    Aug 18, 2007
    664
    Northern Illinois
    Replaces the core plug on the right side of the
    engine just below the turbocharger, according to instructions. Never done one. With the factory start assist system ours has started at 10 below although not too nice on motor. Down to 0 no problem. Block heater is much better for the engine.
  13. z656
    z656 Member
    Dec 7, 2007
    15
    ohio
    block heater
    Thanks Komastu 150 for location install went well
  14. Komatsu 150
    Aug 18, 2007
    664
    Northern Illinois
    Your welcome. If the heater uses the same goofy hardware to hold it as the ones from Cat that we used to install on 3208s, I'd keep an eye on it for a while. Had at least two jump out of the block.
  15. Steve Frazier
    Steve Frazier Founder
    Oct 31, 2003
    5,556
    LaGrangeville, N.Y.
    Just out of curiosity, I'm guessing the 3204 is a four cylinder version of the 3208. Is it an in line 4 or V4?
  16. 992G
    992G Well-Known Member
    Jan 24, 2008
    120
    Illinois
    It's an in line 4.
  17. Komatsu 150
    Aug 18, 2007
    664
    Northern Illinois
    I don't know if any internal parts are actually the same but was supposed to be a 3208 "cut in half". Our 943 originally had 2 ring pistons and that's one compression ring and one oil ring! Ours and a couple others in town that I know of got good service out of the engine. They put the same engine in the 953 with a turbo and it had a terrible reputation.
  18. 992G
    Jan 24, 2008
    120
    Illinois
    The 953 from what I remember was very notorious for dropping valves. If one of these engines made it over 5000 hours, you were doing good. The 3204 was kind of know as a throw away engine.
  19. z656
    z656 Member
    Dec 7, 2007
    15
    ohio
    Komastu 150. Been checking on block heater install seem to be holding up well 2 weeks seval big snow pushes.Steve Frasier yes inline four cylinder
  20. Komatsu 150
    Aug 18, 2007
    664
    Northern Illinois
    Great, after all these years they probably improved the design. Cat is usually pretty good at that.
