Metalman 55
On our 318BL excavator, everything works fine but the swing seems to be weak on it. No noises or nothing loose etc., just kind of lazy.
Ser # is 3LR00468
Anyone know what pressures should be feeding into the hyd motor? If the motor was quite badly worn would the temp on the outer housing be elevated from bypassing? I have not checked the temps but could do it.
We replaced the main hyd pump a year ago ($$$) & everything else works fine on the excavator.
We don't put a lot of hours on the unit, but would like to see if it can be improved.
Ser # is 3LR00468
