Die hard
looking To install block heater on my 2010 cat 305 .
i called the dealer cat makes one (for $350 ) as seen picture/diagram .when searching the web I’ve found a bunch of expandable ones that go in freeze plug hole . one of the ones I saw online went in freeze plug hole and bolted in the two holes either side of freeze plug like in picture on side of my block. Only problem is I can’t find that type to fit my engine .
Anyone ever install block heater on there 305 ? Do you suggest I get one from cat or should I keep trying to find bolt on freeze plug style heat ? I do like the style heaters that circulate the fluid .don’t like adding a cheap expandable style heater into freeze plug hole in the long term I know it will fail .
my ac has no problem cooling the cab this time of year
