searcyfarms
2020 year and running on hi flo with Vail Extreme Mulcher
Engine seemed to kind of surge but I think it might have been pulsing hydraulics loading the machine, a little jerky movement. I was in turtle mode max at 16
After 30 seconds and what seemed to be derated power/hydraulics beacuse it would barely move, I kicked off the mulcher and it popped up a triangle with exclamation point. It woudl only run about 2000rpm I turned the engine speed down to idle, checked diagnostics, no codes.
I turned it off/restarted with the aux hydraulics off, and it was surging in fwd trying to get off the job site.
I made it to my house from the neighbors ( my job site ) had to shut it off 3 or 4 times in a 1/4 mile becaue it just didnt have power to go with the hydraulics. Out of those 3 or 4 times it beeped a couple times and the Triangle Exclamation point came back but then turned off the last time and I drove to the shop and shut it off again. Now sitting still if I run up the rpm and kick on the mulcher head it will spin up for about 30 seconds and then its like the hydraulics hit a second gear and it loads the motor and will stall if you were to keep the button pressed for aux hydraulics.
any thoughts since I do not get any codes ?
The vail mulcher spins up ok and doesnt make any funny noises but when what i am thinking is some valve in the hydraulics opens for maybe high flow thats when it wants to stall.
its full of hydraulic fluid, no funny noises
