Cat 268B Hydraulic/throttle up problem
zlssefi
Connecticut
Thank you Mark!!!! I am going to print this and bring it next door and try to get an answer on this. Much appreciated!
zlssefi
Connecticut
I have an update on this machine. Today the mechanic removed the work pump from the machine and found the actuating piston in the pump to have a sealing ring that got knocked off, and was wrapped around the spring that is below it. When the ring came out of its retaining groove it scored the wall of the bore where the actuating piston seals/rides. A bearing repair sleeve is going to be installed to repair the bore and will be reassembled. thank you very much for your help so far!
zlssefi
Connecticut
Bingo! a machine shop repaired the bore, the piston and ring were reinstalled and the pump now makes 300 psi at idle instead of 2700. Thank you all!
zlssefi
Connecticut
its tough to remember that far back.....but as i recall everything was pipe thread on the gauges and lines.
