MR.ROGERS
Cat 143H transmission, after 1 hr of operation,4-6 reverse won’t engage, after using it for 30 minutes reverse 2-6 won’t engage, raise rpm then reverse gears engage, Oil,filter and screen clean
Serial# 1AL000097 the tractor is great for 1st hour of operation, every gear engages, then 4th reverse has a pause before engaging, after 2 or 3 times, it stops engaging,from that point using machine continuous,Foward gears start not engaging when changing direction, after another 30 minutes of use, at one point engine Rpms had to be raised before any gear would engage, All of the oil, filter have been changed,using Cat TO 4 oil along with checking screen the system is clean, oil is clear, including the oil that was drained, Thank You for your Help. I’ve changed Gear Selector, trans was rebuilt by caterpillar just over a year and half agoCan you explain the symptoms a bit more clearly please. You start by saying “after 1 hour” then go on to say “after 30 mins”. Which problem comes first.?
Does the oil appear dark & cloudy or clear & bright.? Does it smell burned.?
Have you tested any pressures yet.?
Also please post a Serial Number.
OK, so that is a VERY early 1AL machine.Serial# 1AL000097
Unfortuately that doesn't completely answer the question. The modifications are in the "guts" of the control valve, not the complete valve assembly which retains the same Part Number as the older style. We'll park that for now but may have to circle back to it later because to check what it has is going to require the valve to be opened up to check some internal parts.The control valve was changed 2.5 years ago,and no it’s the original style
A good start. You're going to need three pressure gauges (preferably identical if you can get them) with a maximum reading somewhere in the 5-600psi range.I can get pressure gauges
Exactamundo. Either the spool can seize or the solenoid coil can break down electrically when the valve gets hot. That's why interchanging both parts (spool & coil) from the suspect clutch to another clutch station is key. Many people think that all you have to do is move the coil from one cltuch station to another which is incorrect.Those electrical solenoids can fail when they get hot. Its a common problem.
And that's the correct oil.Cat recommended using 30# T04 that’s what is in there now,
Sorry to keep banging on regarding this issue. Originally you said you lost 4-6 reverse after 1 hour of operation. Now you are losing all gears except the one you are in at the time. It sounds as though the more the machine has been worked since the problem started the more gears you are losing. Is that a fair description.?When I lose gears it’s All of them except the the ones I was using , which is 3rd forward and reverse.
