Ronsii
- Joined
- Jun 26, 2011
- Messages
- 3,464
- Location
- Western Washington
- Occupation
- s/e Heavy equipment operator
Hi everyone at HEF... I have a little problem and need some help
So we have a case cx36B 2007 bought it new has about 5800 hours on it... it has been maintained fairly good and been a good little machine. I apologize in advance for not having the pump details or engine for that matter...(sorry pumpguy) It was pretty hot at the site today so my brain was just about fried when quitting time arrived but I will get numbers as soon as I can. I do know it has a yanmar engine in it I think the 3TNV88... I know it uses this shutdown solenoid ->
About a month ago it just died while using it, just like you shut the key off... fuel gauge read just below a quarter so just assumed it had something to do with that... filled er up and started up ran great! now in the last two days it has died about 20 odd times sometimes it'll start right back up sometimes it will die a second time or you wait a few minutes and she's fine again???
So thinking this might be electrical I started tracking things down and only questionable thing in there is the kill solenoid, put in a new one seemed to work fine... thinking it was fixed went to load it up this morning and it died a few times Found that it will run without the kill solenoid installed so today when it died the second time and would not restart I pulled the solenoid off the engine then tried to start... wouldn't start... so I poked my finger in where the solenoid goes a few times gave the spring plate a little exercise and than it started!
I am really hoping someone (especially pumpguy) has some ideas on any other troubleshooting to try or if this sounds like the IP is going out... or something completely different....
One other thing is it seems to die mainly when at idle, it doesn't seem to make a difference when trying to start if you have throttle up or at idle and every time it dies it quits instantly just like the key was turned off, also it has been fairly hot here lately... oh haven't checked fuel pump pressure but hear it working and if the solenoid is pulled and you turn the key off it will run for at least 5-10 seconds without fuel pump running.
