CASE 850C Track Loader(Who owns or runs one?)
Discussion in 'Track Loaders' started by roadrunner, May 19, 2009.
  1. roadrunner
    roadrunner Well-Known Member
    Feb 5, 2008
    148
    Saskatchewan, Canada
    I just bought a 1981 Case 850C track loader and was would like to know what you think about this machine!
    Have you had any problems and maybe anything I should look for or extra preventive maintenence I should do?
    The under carriage is wore and the sprockets are shot, so I will be putting new ones on shortly.Other wise runs nice,no smoke,seems strong and in decent shape.I sure hope it isn't a dud because I need it to make some money first!:D
    roadrunner...
  2. roadrunner
    Feb 5, 2008
    148
    Pics!
    Here are a few of my machine!
  3. gggraham
    gggraham Senior Member
    Feb 13, 2009
    308
    Licensed Heavy Duty Equipment Mechanic
    This dozer has the 336 in it. If I was you I would drop the anti freeze unless you know for a fact it has been changed within the last 1000 hrs. Don't need old anti freeze with a screwed up PH level causing sleeves to pit and leak anti freeze into the engine. The only other item I would check is the small hose from the water manifold to the water pump. These had a tendency to crack and split open, if the anti freeze need to be changed it's a perfect time to change this out too.
    The transmissions in these dozers were rock solid, seen them with 10,000 plus hours with no problems.
  4. roadrunner
    Feb 5, 2008
    148
    Thanks for the great advice gggraham!
    I sure will change the antifeeze now.Forgot about what nasty things can happen with poor antifreeze.
    Is this engine preety good or what do you think?I am very glad to hear about the strong transmission as I was very leary on their durability.
    I will be able to tell you more about it when the machine gets delivered the end of this week.
    I gather you pull wrenches for a living, so I may have some more questions for you later on!Thanks again for your knowledge. I appreciate it!:)
    Would you or anyone else know where I could get the Service and Parts Manuals for this 850C Case?
    Let me know or PM me!
    roadrunner...
  5. gggraham
    Feb 13, 2009
    308
  6. roadrunner
    Feb 5, 2008
    148
    Thanks for showing me where to find the parts manual.Ilooked at it and it will be very helpful.
    Now is there a service manual on line?:beatsme:)
  7. amunderdog
    amunderdog Senior Member
    Apr 24, 2009
    280
    Sunbright,TN
    Well how is it?
    I have a simular question.
    I am looking at an 850B
    two foot peddles on left?
    one on right?
    with an accelerator or decelerator peddle?
    Then they have three levers in front of you.
    i saw on the 1150 they had high low - left right - track speed. does the 850?
    Anyway lets hear about your new ride.
  8. sandy
    sandy Well-Known Member
    Aug 16, 2007
    48
    diesel mechanic
    850 b
    Left brake, right brake first part of pedal travel disengages drive to that side.
    levers forward reverse and left and right high low neutral
    plus another lever below for high and low range
    strong simple trans
    if you have the tracks off i would off pull final drive pinion out and inspect
  9. garr_trenching@
    garr_trenching@ New Member
    Apr 15, 2008
    4
    Fairfield, Ia
    We have a 850 D, great little machine. Only problem we had was someone put brake fluid in the master cylinders instead of hyd. oil. ruined the seals and o rings and caused the pedal to stick disengauged.
  10. roadrunner
    Feb 5, 2008
    148
    Yes all the pedals and levers are what you said.Ihave done quite a bit of work with my machine and really like it.Just like others have posted before - they are truely an all purpose machine. I can dig,grade, load,pile,seperate,stump,lift,haul,sort,screen,etc.,etc.:D
    Only problem I have right now is the left front idler bearing went and I need to fix immediately.The under carriage is worn to about 20-25% left.I would like to make it till winter then do new under carriage then.
    Anyone have any pointers in splitting the track and pulling out the idler to fix the bearing?I have never done this before!:eek:
    roadrunner...
  11. amunderdog
    Apr 24, 2009
    280
    Sunbright,TN
    How much does an 850 track loader with rear weight weigh?
    I looked up 18,000 The current owner thinks 21,000
    The one i am looking at is abit rough. But i think it will be ok.
  12. OneWelder
    OneWelder Senior Member
    Apr 12, 2007
    483
    Derry, New Hampshire
    Years ago I did a lot of repair and maintenance work for small builder operations.I did a lot of work for this one individual who was a loud mouth, but very entertaining.
    Anyways I put a bottom on his first machine. just happens to be a case 850 - He and his kid decided to grease machine after using it a few days . Pumped and pumped and keep pumping grease into that grease fitting (Track adjuster) but could not get the grease to come through, When he come and got me because the ft. wheel was making funny noises- The bearings were completely gone- shaft was pushed against the idler and tracks were still so tight they did not touch the top roll
    Same guy told me it was a waste of time to grease every day , just add a little extra - In other words put in 7 times as much grease and only grease once a week
  13. Wolf
    Wolf Senior Member
    Apr 5, 2006
    1,203
    California
    great looking machine. what kind of jobs are you using it for?
  14. cgraham1
    cgraham1 Well-Known Member
    Mar 6, 2009
    76
    Redding, California
    My dad has a 1450. It's got a 4/1 bucket w/ rippers on the back. He got it for $4500, but the tracks would only turn if they were in the air. Turns out it just needed a small spring inside the transmission to fix the problem. Seems to be a decent machine now!
  15. alrman
    alrman Senior Member
    Jun 20, 2009
    2,064
    QLD Australia
    Release the track adjuster.
    It could have a master pin (only one with a dimple in it) which you will have to drive out - 14lb hammer is good choice.:( It may need a little heat on the chain link. When you refit - drive the pin from the inside towards the outside - that way if you should bruise the pin during installation, will be easier to drive out next time!)
    It could have a joiner link - alligator type or 'c' type - remove the grouser plate & tap with hammer - 2lb is fine.;)
    Idlers don't often repair too easliy - they often need machine shop work to repair the damage caused by the failure - unless you can do this yourself, it can be expensive. Shop around & look for a new one.
    PS If your idler does not already have them - the new idlers have rubber spring blocks & spacer plates that will need to be purchased - usually genuine CNH
  16. roadrunner
    Feb 5, 2008
    148
    Thanks for the advice guys. I just purchased a new complete under carriage:eek::eek: , and run into what you said "alrman". Idler needed a machine shop for quite a while!
    The rest of the machine seems tight. I have a ripper on the back and am thinking I should put on my counter weights because the ass end of the machine gets pretty light with a full bucket.Would the weights be the best for the machine to put back on?Full buckets could also be hard on the front idler and under carriage, with the ripper only on right??What do you guys think?
    I never used the ripper yet so I might as well take off.
    I have been doing some landscaping,pad work,tree removal,garbage fill work lately and am really enjoying it!(after I spend 12hrs on my grader each day!):(
    roadrunner...
  17. poorboy
    poorboy New Member
    Apr 22, 2011
    1
    alabama
    I have a 850c i found a tag that said it weighed 26,500.00
  18. 22a
    22a Well-Known Member
    Feb 8, 2012
    54
    Worked an older 850 (1968) loader, found them to be a good machine.
  19. Lalovilla
    Lalovilla New Member
    May 29, 2012
    3
    Alberta Ca
    Hi my 850 wont go untill the oit in the tranny warms up does anybody know if theres a filter or screen somewhere that might need to be cleaned? Once its warm it works but still seems a little weak. Also what kind of oil should a guy put in the transmisssion? Ive heard of using a lighter weight motor oil?
  20. alrman
    Jun 20, 2009
    2,064
    QLD Australia
    Welcome Lalovilla!
    I am assuming you have an early 850 & not an 850C? ....
    This problem usually indicates that the transmission pump is sucking air. If all the suction hoses are in good order & clamps are tight ( no oil leaks while parked?) the problem could be the pump itself.
    There are a few configerations of this pump - do you have a serial number?
