Thanks for the pressures. I ended up with 2 different problems. A brake pump that went bad and a stuck spool on the bottom half of the brake valve. Replaced the pump and cleaned the valve, works like a champ!I'm assuming your getting a low brake pressure fault. Check your brake charging valve adjustment.
cut in pressure 1900-2000psi
cut out pressure 2700-2800psi
accumulator charge 800psi
brake cylinder pressure 1250-1350psi front, 1200-1300 rear
Valve is on the rear right side of machine. Look in the Case ce parts website for a better visual of the valve. There is a hole in the frame so you can adjust the allen screw and set the pressure.
Are your front or rear diffs over filled?
