Phil
- Joined
- May 2, 2005
- Messages
- 1,067
- Location
- Southeastern Ontario
- Occupation
- retired operator and mechanic
I got up at 4:30 this morning and started thinking about it. ATCOEQUIP would even agree it's pretty early even for me.
"The quick connect on the outlet hose coming from the backhoe valve came off."
That would do it, better than the collapsed pressure hose idea I was considering. I was even thinking maybe it's really a gas engine here, even though you mentioned a shut-off cable, and have one of the 2 coil power leads defective.
The relay above the starter as I mentioned before, is only for the manifold heater. It should have one heavy lead, maybe a #6 wire, from the starter positive terminal to one of the relay's large terminals. The other large terminal on the relay is connected with the same gauge of wire to the heater. The relay needs to grounded, by bolting it to the engine block as Case does with 2- 1/4" bolts. There is a spot for it. The only other lead needed is a #14 wire powered from the push button switch, located near the starter switch, to activate it. It appears some of your existing wiring is incorrect.
The clicking may be this relay somehow activated by the 'start' terminal on the starter switch. This is not desirable, and if used, the heater should only be on before cranking.
These heaters are quite robust and usually still in working condition. I believe 1 minute is the maximum time you should have this on before attempting to start. I find that 30 seconds is just right and allows starting(without ether of course), to a lower temperature. I have never had a 188 diesel start at a temperature lower than about 32 deg F , unless plugged in or using ether. The manifold heater allows easier starting down to this temperature. Phil
