Greg in KY
I bought a 580C about a year ago. It has the Case motor.
Since I bought it the starter would click maybe 5 maybe 50 times before it would engage. It never failed to start. The previous owner said it had been like that for a while.
The other day I decided to fix it -assuming it was the solenoid.
I had the starter rebuilt at a local starter/alteration shop that does good work. They said it tested OK but changed the solenoid anyway based on what I told them it was doing.
I put it back on and it does the exact same thing. When it "clicks" but does not engage- it does make a solid, firm "click" . I checked the schematics in the service manual and found the is nothing but connections between the starter button and the starter. The connections in the dash feel good and tight. I didn't take the time to find out where the neutral switch is located.
Now my 2nd best guess is that there should be shims or something on the mount for the starter - but - I have jumped it with a screwdriver 3-4 times at the starter and is engages perfectly.
Any idea of what the problem is?
Thanks, Greg
Thanks, Greg
