Hello, new poster here. We have a 580B with the shuttle stall problem. After reading quite a bit on here, we decided the shuttle pump/control valve was likely causing the problem. After pulling the shuttle cover plate, the suction tube screen was about 1/2 covered with gunk, as many people here have found. The pump shafts were wore quite a bit as the drive gear had excessive side to side motion. The gears appear worn slightly (approx O.D. = 1.700"), but could probably be salvaged. The housing and cover have light marring (less than 0.020") and could be resurfaced.
This pump appears to be an aftermarket pump, with the bushings being split bushings and made of thin material. While the case-o-matic farm tractor pumps we have are thicker & solid bushings.
After all that, my questions, has anybody been successful in rebuilding one of these shuttle pumps? Or has anyone heard of converting one of the case-o-matic farm tractor pumps for use in a 580B? Anybody willing to part with a used pump in fair condition?
Thanks in advance.
Thanks in advance.
