case 580 ck help transmission
Discussion in 'Tractor/Loader/Backhoes' started by born2ride, Apr 18, 2010.
  1. born2ride
    born2ride Well-Known Member
    May 30, 2008
    159
    Automotive Tech
    Flemington,NJ
    Thanks for the help on the HD-5!! So i am back again..Well we picked up this case it does not move forward or reverse. starts and runs well,load and hoe work. think its mid 70 era. I figured out it has a torque converter because the gauge reads zero psi..
    i found this plug on the right side of machine.. It seems to have gear fliud in it.. I was thinking it was a fill for the converter pic.
    http://i125.photobucket.com/albums/p79/borntworide/IMG_6864.jpg
    so i need a direction to go.. i need to know how ,where to fill and check trans fluid.
    pix of machine
    http://i125.photobucket.com/albums/p79/borntworide/IMG_6865.jpg
    thanks B2R
  2. Phil
    Phil Senior Member
    May 2, 2005
    1,067
    retired operator and mechanic
    Southeastern Ontario
    I can't see the plug you refer to clearly. If a torque converter drive, the shuttle oil fill will be the large plug/ dipstick on right rear corner of the shuttle cover. This cover is just in front of the transmission cover. Note that the trans/diff uses a different type of oil and it's plug/dipstick is located just behind the transmission cover.
    Torque drive models usually have their shuttle oil filter located just in front of the radiator.
    In your spare time read the lengthy thread "My 580B won't even move", one this same page. Many of your questions will be answered there. Phil:)
  3. s1120
    s1120 Well-Known Member
    Apr 14, 2010
    104
    NY
    Is it normaly real hard to see the fluid on the stick?? I just got my 580ck yesterday, and was checking all the fluids.
    Here is a pic of the plug Phil is talking about.
  4. born2ride
    May 30, 2008
    159
    Automotive Tech
    Flemington,NJ
    Thanks I see that plug and checked it.That one has rear fluid on it
    @Phil
    Searching for the post.. thanks
  5. s1120
    Apr 14, 2010
    104
    NY
    Ya, the torque converter drive takes the same fluid as the rear. The Case TCH fluid
  6. born2ride
    May 30, 2008
    159
    Automotive Tech
    Flemington,NJ
    My machine seems to be a 580 ck.. I noticed here that 580b ck is similar but how much?
    I am a little confused the large plug in front of shifter is for torque converter. so it takes TCH fluid (similar to atf) which is not 80-90w..
    The plug behind the shifter is for the gear box/trans. which takes the 80-90w
    The other thing i need clarified is the location of the shuttle screen to be checked. I came across two confusing pic..
    first one
    http://www.heavyequipmentforums.com/Forum/showpost.php?p=157505&postcount=22 do i need to split the tractor to see clean this filter?
    sec one
    http://www.heavyequipmentforums.com/Forum/showpost.php?p=160426&postcount=80 what is this screen for?
    Thanks in advance
    UPDATE;
    Pulled the shuttle drain plugs got at least 1 gallon of water out plus all the nasty fluid.
    Off to get fluid and filter for flushing...
  7. born2ride
    May 30, 2008
    159
    Automotive Tech
    Flemington,NJ
    Good new..new fluid and she started to move!!! A little sluggish but maybe a new filter and another change will help..
    Another question .. removed the hoe off the rear.. I assumed the feed line with the quick disconnect would reconnect back to the other one so the hose would not drag.. The fitting keeps leaking.. reconnect back to hoe no leak. Any thought?
  8. Phil
    Phil Senior Member
    May 2, 2005
    1,067
    Born2ride,
    The second link you posted shows the screen and adaptor plate removed from the machine and upside down.
    A working dash gauge makes it easier to monitor clutch apply pressure. Various pressure checks on the shuttle system, should be done with a 0-100 psi gauge, a 0-500 psi gauge and a length of hydraulic hose (1/4"), if troubleshooting.
    The torque converter on a 580CK or BCK cannot be drained as I recall so a second oil change would be a good idea. There is a drain in the bottom of the filter housing also. I think I would replace the shuttle cover gasket and make sure the fill plug has a copper washer under it.
    The only thing I can remember about the big disconnect is to reconnect it together before starting the machine and driving away from the hoe. Sometimes a leak can be stopped by replacing the o-ring, just inside the bore of the female connector.
    Thanks for the pic s1120. Phil:)
  9. s1120
    Apr 14, 2010
    104
    NY
    No problem. Im a bit of a picture whore... You will see a lot from me. :D
  10. born2ride
    May 30, 2008
    159
    Automotive Tech
    Flemington,NJ
  11. Phil
    Phil Senior Member
    May 2, 2005
    1,067
    I could not bring up your link for some reason. The shuttle filter is located just in front of the radiator, mounted in the bottom left corner of the opening, behind the grill. Remove the filter housing cover(4 bolts) and the filter will lift out.
    The shuttle pump intake screen requires much more work to access, and is not part of regular maintenance. Phil:)
  12. born2ride
    May 30, 2008
    159
    Automotive Tech
    Flemington,NJ
    Thanks Phil the pic in question is on post #6. 1st link that one works.. I checked it. just confuse on where that is and how to access it..I am just asking for educational purpose.. thanks B2R
