case 450 dozer pulling problems
Discussion in 'Dozers' started by mffcl, Dec 30, 2013.
  1. mffcl
    mffcl New Member
    Dec 30, 2013
    3
    great falls sc
    I've got a case 450 dozer unsure on year. when we got the dozer the owner said the torque converter was just rebuilt. after running the tractor for about 30 min it will stop pulling the drive shaft stop turning. you let it set for a while and it will pull again for about 30 min again. what are some possible causes for this problem and how to fix them.
    thanks
  2. Dozerbill63
    Dozerbill63 Well-Known Member
    Nov 12, 2012
    57
    Repton , Al.
    Check transmission fluid level , is it full , maybe the transmission filter clogged or collapsed , suction pump screen could be clogged . Do you have a service manual ?
  3. mffcl
    mffcl New Member
    Dec 30, 2013
    3
    great falls sc
    I think I we have the manual we haven't checked yet looking for a place to start checking
  4. Dozerbill63
    Nov 12, 2012
    57
    Repton , Al.
    Have you checked your transmission stick under your seat , is it on the full mark ? Also if you have a leaking transmission hose , it can suck air and cause tranny from pulling, If you remove your tranny filter , be sure you remove the valve in the filter and reinstall it in new filter , that valve cost $200.00 so be sure you remove it before discarding .
  5. mffcl
    mffcl New Member
    Dec 30, 2013
    3
    great falls sc
    We haven't checked yet that is first on the list
  6. Dozerbill63
    Nov 12, 2012
    57
    Repton , Al.
    Were you able to get your 450 pulling ?
  7. Cam85
    Cam85 Senior Member
    Nov 15, 2013
    273
    Roma
    Mffcl how u goin with it mate, Dozer bill has some good things to check 1st, I've got a head full of things to check.
    But unwed to tell us wat ur up to so as wee can help.
  8. Dozerbill63
    Nov 12, 2012
    57
    Repton , Al.
    450 troubles
    Hey Cam how are ya ? Guess our friend is too busy working on his 450 to talk !:eek:
  9. Davidonmars
    Davidonmars Member
    Nov 19, 2015
    15
    Intario
    I have a 450b and have a similar sort of problem it'll move when it's cold but no real umph to it and doesn't like to turn almost like the tranny is slipping in an automatic car and it gets worse as it warms up any ideas?
