Hydro whine loudly appears in between idle and half throttle, quiet at half, loud again in between half and full. Loudest right above idle. Somewhat quiet at full. Noise mostly disappears when boom, bucket, or auxiliary hydro circuit is operated. Noise remains when machine travels. Machine only has several hundred hours.
Basically the rubber line from the gear pump to the "IN" of the loader control valve starts vibrating badly, with the main noise coming from the steel line from the "OUT" of the control valve to the hydro filter... starts resonating/virbrating badly. I can change the noise by grabbing the line and moving it, but cannot make the noise disappear. I suspected gear pump part of the problem, but when under load noise goes away. Auxiliary circuit pressure was 3313psi when oil was warm, not hot. Machine has plenty of travel, boom and bucket power after an hour of hard use in 90 degree temps.
I tightened the band clamps from the suction line out of the tank to the gear pump. No difference.
Before I change the hydro filter and fluid (think it was the original fluid from factory) the noise was worse. Filter sock was dirty (looked like aluminum residue) but no metal shavings, very small amount of shavings came out of bottom of hydro tank, but hardly enough to concern me.
Any thoughts?
Gary - do you have a pic of that hose that was supposed to quiet excessive hydro noise? Thank you!
Any thoughts?
