Shimmy1
Been getting warmer this past week, and noticed that the inside the cab was getting warmer as well. Have had the condenser get full of debris before, so tried that first. Spent 20 minutes blowing everything out, no change. Snapped gauges on, high side appeared to get a little high (around 275 psi), but low side looked ok for the most part (would come down to about 18-20 while compressor was running). Was expecting to see the low side lower, but went ahead and added some juice anyway. Added around 8 oz, low side started running about 25 psi at compressor shut-off, and air was noticeably cooler out of the vents. Now for the strange part. Air gets colder ONLY while compressor is running, warms back up when compressor kicks out. But the most disturbing fact is how the high side acts after I added refrigerant. The compressor kicks in when the low side is at about 45, and the high side is at 180. The low side gradually comes down to about 25, but the high side goes up to about 330-350, then starts dropping, and continues to drop while the compressor is running. Compressor cycle time seems legit, about 20 sec on, 20 sec off. I'm leaning towards there being a restriction somewhere, like a bad dryer, or a malfunctioning expansion valve. Anybody have anything different to suggest?
