rico7467
1996 case 1845c with m46 tandem drive pump. Pump is completely rebuilt and new drive motors as well. When you get into a load in forward and reverse the machine just sits and tires do not spin on either side and engine does not die down it just runs wide open as if . Is it possible that all 4 SCR VALVES are bad? What are some tests I can run? I've already checked the charge pressure and it is fine even when u put it into a load it is still up high.
