Dadnatron
We recently purchased 80+ac of beautiful bluegrass farmland and want to build it into a horse farm. This means roads.
I will have roughly 1.5m of roads over the place, when all is said and done, however, I must build about 1/3m of road for barn access before I can do anything. In order to free up $$$, I have to get my horses on our place. They are currently boarded, so I am in a fix. In order for any more significant $$$ to be spent, the road has to be put in to an old tobacco barn we will be refurbishing into a horse barn. But to have the $$$ to have the road built, I have to have the $$$ freed from the horses. One BIG Catch 22.
I had a recent quote for road construction, and it is far out of my range at this point. Roughly $26.5K which DOES NOT include aggregate. That is the grading, culvert, and fabric installation along with pre and post aggregate packing. To be fair, the road is on a small hill, but he said he would just build right up the hill, along the slope. There are no trees etc. There is a place around the barn requiring grading to prevent water running into the barn. I can easily drive along the route I desire the road to take, but it is just along the winding edge of a field with a sideways 'cross grade'.
Regardless... I can't afford to have it professionally completed. I don't have a problem paying for expertise, but I just don't have that kind of money at this point.
I currently have a 100hp JD tractor with FEL. I also have a 6yd scraper which the tractor fills without issue. And a 12ft Killifer blade and box blade with hydraulic scarifiers. I've used both to do a lot of dirt moving around the farm, and I believe I can do quite a bit of the dirt work with these implements. But, cutting into the hill will be more of an issue.
I've never used a dozer, but they seem to 'be the thing' to build roads. I have rented small excavators as well, and I think I could do the cut with the excavator. I have some CTL experience, but would in no way be more than a novice at either. I am fairly good with using heavy machinery (growing up on a farm) so I'm comfortable learning and working them.
The cut would be about 3ft high, moving dirt from high side to low side. I want 11ft finished gravel so I was thinking I would need to build around a 13ft wide base not including high side ditches.
My question to you is what would you recommend for the excavation? I can strip the topsoil with my scraper, I believe. But I'm don't think I would be able to make the cut well. Would you recommend renting a dozer or excavator or something else? Any recommendations for anything else 'road building related' is also appreciated.
I've also thought about asking about 'hiring' the road builder as a consultant. Paying him a rate for his direction but doing the work myself. I would really like this, as I really like him, I just can't afford his company. How do you think an Excavation contractor would feel about being asked this question?
