tool_king
Brand new Miller CST 280 Welder Asking Price $1700.00 .Was bought for a job but never used .
This welder can be left out in the weather not to be worried about while working .Was taken out of storage box for pictures .
Features:
• Easy voltage changeover between voltage ranges through a two-position manual switch. Conveniently located on the rear panel, it simplifies voltage change in racks. • Simple to operate with a process selector knob which automatically sets the proper dig setting on E6010 and E7018 electrodes providing superior stick performance.
• Lift-Arc start provides arc starting without the use of high frequency.
• Fan-On-Demand cooling system operates only when needed providing power efficiency and noise reduction.
• Stand-alone or rack-mounted for construction sites. commonly used in construction and shipyards, are available for multiple operator applications . All controls including the power switch are located on front of the machine for easy access.
• Compatible with Wireless Remote Controls. Improve productivity, eliminate clutter and cord tangles in the work area. Eliminate cord failure and associated downtime/repair costs and extend the operator's welding range without adding cord extensions.
• Remote amperage control provided through 14-pin receptacle on front of the machine. This permits use of standard amperage control devices.
• Line Voltage Compensation (LVC) keeps output of the power source constant regardless of fluctuation in input power ± 10%.
• Adaptive Hot Start for Stick automatically increases output amperage at the start of a weld should the start require it and prevents the electrode from sticking and creating an inclusion.
Applications:
• Power Plant Construction
• Petrochemical Construction
• Maintenance and Repair
• Shipbuilding
Features:
Applications:
• Shipbuilding
