powerjoke
- Joined
- Aug 2, 2009
- Messages
- 1,125
- Location
- Missouri
- Occupation
- owner/operator/estimator/mechanic/grunt/ditchdigge
I have a F1L 210D on a 4" Gorman Rupp water pump,
Spun a rod bearing and broke a piston ring,
I need help locating a
Con Rod
Rod bearing (not sure what undersize yet)
Gasket set.
I found some parts at 1 place but I want to price check them a little, they wanted $350 for the rod, $75 rings and $150 for the gasket set....
I would also consider another motor if someone has one. I would also like any used parts as the whole damned pump isn't worth $2500
Edit: serial number is 7935950
Pj
Con Rod
Gasket set.
Pj
