Bosch RSV governor question
Ct Farmer
Connecticut
I have a question on a Bosch RSV governor on a P series pump. The engine is a Volvo TD103KAE. The entire throttle control system has been rigged by a previous owner and I am trying to straighten things out. Throttle is controlled by a linear actuator and fuel shutoff is done by an electric fuel valve in the incoming line.
My question is what do I do with the manual shutoff lever? Tie it down in one position? Let it float? My shop manuals don't mention it. It is internally spring loaded upward. With a push up it clicks against a stop. Push down, let go and it jumps up.
Previous owner appears to have had a peace of wire tied to it. Thanks for the help just don't want to cause any damage by missing something.
Thanks for the help.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Just push it against the stop [up] & leave it alone.. the spring will keep it in position..
IF it makes you feel better you can wire it..
