bigboytoy
I have a 2006 T190 with foot controls. The tilt on the right foot is easy and smooth to engage. However the left foot control which has more linkage is stubborn. It is difficult if not almost impossible to raise and or lower the arm smoothly. When looking at the movement I see it travels about a half of an inch then it jumps (break through?) jerking the arm up or down a quick foot. I have changed all points of linkage with no help. I have removed the detent springs and ball on the spool. Its seems like pressure is tightening the spool. I am going to remove the BICs lock out solenoid in case it is hanging up? More RPM it jumps even more. with a load it bounces me around pretty good. I know I should buy a cat, but $$$$. Is this normal any ideas people?Thanks
