BobcatBucky
Hello all,
I am having an issue with the battery on my t190 not charging. I recently had to have the loader recovered from a creek where the battery and lower 1/4 of the engine bay were submursed for about an hour. Afterwards I drained everything I could think of, checked all the fuses and relays and could not get it started. After talking with the local dealer, I bought a new starter, hooked it up and she fired back up.
About an hour into work after getting it running again, the machine beeped 3 times then showed the acs light and locked the hydraulics for the arms and bucket. I shut down the loader, then went to restart and it said system voltage to low and would not crank. I disconnected the battery and put it on the charger for about 40 minutes then connected it back up and it fired up no issue. I cautiously ran it while I watched the vitals on the computer and noticed the battery is slowly draining.
Went and bought a new battery just to be on the safe side (the other one looked to be about 8 years old from the date code) put it in, and still have the same issue.
Other than the battery drain, the loader is running great and I have no active codes.
Any thoughts on why the alternator might not be working?
