Bobcat S220 Skid Steer Bucket Tilt Leaks Down.
Discussion in 'Skid Steers' started by pete13, Sep 26, 2011.
  1. pete13
    pete13 Member
    Sep 25, 2011
    5
    denton texas
    I have a bobcat s220 and the bucket tilt falls on its on and it does it on or off. both tilt cylinders are rebilt and still have same problem.. I have did everything possible looking for a leak and cant find one.. i dont have a schematic or service manual.. so im looking for some input on what to check next. thanks for any help
  2. tool_king
    tool_king Senior Member
    Mar 29, 2010
    819
    road mechanic owner
    new jersey
    How fast is it drifting down .The curcuit does not have a holding valve on it.Pete it could be in your spool valve also.If you take the barrel side hose with the bucket raised off the ground ,engine off no oil should leak from cylinders .You could also try and cap the barrel side off and see if it drifts down.
    Pet also check out Understanding hydraulics and cylinder drift in SHOP TALK section may shed better light on the problem for you.
  3. BDFT
    BDFT Senior Member
    Sep 12, 2010
    265
    Northwest BC
    A lot of drift is standard in a Bobcat. Something like an inch an hour is still within the parameters.
  4. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,488
    Service Manager
    Knoxville TN
    I agree with tool king. With loader arms down and bucket resting flat on the floor, disconnect the two hoses from the loader arm pipes that feed the bucket tilt cylinders, plug and cap those fittings with JIC caps and plugs. Start engine and raise loader arms raising bucket a couple of feet off the ground, shut it down. Monitor bucket for drift. If it holds, problem somewhere in control valve.
