Ha, what a coincidence...I was just looking online as to what coupler I needed to test my machine's hydraulic pressures, and you have the same deal...
So far, I have figured out I need a flat faced hydraulic quick connect coupler...problem is, I don't know what size (1/2" or 1/4").
Not only that, I see prices from a $100 to $12 (UK).....
Just need a friggin coupler so I can check pressures....
So, you need a female coupler...size, I don't know. Problem is, once you put a coupler on that, the pressure will be released rather quickly...what kind of pressure could there be in an oil cooler?
For starters, I'd have a hose on the coupler, so oil isn't sprayed inside the engine compartment....if you can find out the model number of kit, you can sometimes find a pic of what it looks like, which would help a lot. Maybe there is a release valve on other end of hose to slowly release pressure...idk
For instance, my pressure diagnostic kit for 331 Bobcat is MEL1355
I recreated the kit for way less than the 1.3k they wanted...just need the right female coupler...best
I saw this:
http://www.ebay.com/itm/PARKER-SM-2...NNECT-COUPLER-1-4-BODY-6000-PSI-/322255719084
Just not sure if I need a flat face female coupler...for instance, my aux line to thumb, it is flat faced...supposedly to limit contamination and a solid locking mechanism so there is no disconnect under pressure.
ISO 16028 Flushface Interchange - seems to be the right ISO number...again, I don't know the size required.
