AllenJames
Posted another thread regarding the engine stall at low rpm. Stuck with a down machine now. Pours out black smoke while cranking. No fuses are bad. Fuel primer squeeze ball is solid.
I was able to free the stuck stems using a bent paperclip to stick up inside the bottom of each stem to work the brass sleeve and spring mechanisms a lot. They were really jammed up. Then reinstalled the stems and coils. Then got flow both directions on the pwm. Yayy! Then the RPMs were too low, the engine stalled while exercising the valves. Now the exhaust pipe pours out black smoke and machine won't restart. Now to hurry up and wait. Yikes! View attachment 172902
