Having trouble fixing trouble code 13-07.
I replaced the solenoid, did not help. I have traced all the power and grounds at the relay and looking at the wiring diagram, I am missing two signals coming from the controller to the relay. Basically I have power to the coming from the battery into #30 on the relay and ground coming into #85. Then I have a wierd quasi ground coming from the computer into 87 that goes away when you turn the switch and then no power or ground on 87 Here is a pic of the wiring diagram. Thanks for any I ideas. BTW I have back probed to the controller to verify connections there.
Also just wondering if the codes need to be reset by the dealer?
