jparr763
I have a used 763 (low flow) that is a b*tch to start when cold (50f or lower). It is a fuel issue, that much I am sure of. It starts by not wanting to turn over at all. Then I go around back, pump the fuel bulb (with pliers because it is so stiff), operate the drain plug on the filter, and the air release on the filter. Honestly, I'm not sure which of those things works, but the next time I try to start it, it sounds like it wants to start.
Often enough, I can start it for a few seconds, then it dies.
After trying these things fairly randomly for a few minutes, it will finally start.
I do use the glow plugs, for 10 slow seconds, but that doesn't seem to help. I checked to make sure they were working by pulling them out, grounding them, and watching them glow when triggered. So I know that power is getting to them, and that they are getting hot.
Any suggestions?
/ Once I get it started, it runs fine the rest of the day.
Any suggestions?
