The machine runs fine for 30-45 minutes and then will only idle.
we have replace the injector pump, lift pump, fuel lines, pickup line with screen in the tank. We have also drained and filled the tank with fresh diesel, we also bled the fuel lines all the way to the injectors.
When it starts to runs bad we have shut it down and found that there is air @ the injectors.
It is a Bobcat model# 763, product id# 512243052
Please help as this is my only bobcat and I need to have it up and running properly!:Banghead
