I have fuel pouring out behind my fly wheel, inside the casing. Motor, hydrostatic pump, drive motors, and just about every hose has been rebuit or replaced. Both rear motor mount bolts were not put back, so I can lift motor up to look under. Fuel lines are not leaking and the fuel is definitly coming out behind the fly wheel. Under the motor is completly dry and the fuel leaks from the fly wheel casing behind the fly wheel. Anyone have any suggestions? I can post a pic if a visual is needed. Thanks!
