So I've had this machine for 8 years or so and it's always had this issue, when I put the aux hydraulics under load and try to tilt the bucket up it tilts down. When they aux hydraulics aren't under a real load everything works fine, like when the brush cutter is already up to speed. It does the same thing when I have the grapple bucket on. Also, it's not like it's in the easy release of hydraulic pressure mode to slowly bleed the bucket down, it's actually sending hydraulic pressure to tilt the bucket down when I try to tilt it up. But like said this only happens when the aux hydraulics are under a moderate load, as soon as the load lessens it works normally. The boom moves up and down normally while this is happening.
I never worried much about it and just avoided tilting the bucket when grabbing stuff but it's not so easy when running the brush cutter and it's trying to come back up to speed. I also seem to be loosing some aux hydro power after the machine is well warmed up and has been worked fairly hard for an hour or so and I'm thinking the two problems may be related, the gear pump only has about 300 hours on it. I'm thinking fluid is bypassing somewhere in the controls but have no idea where to look or how to diagnose it. I'm an auto mechanic not a hydraulics guy. Any help would be greatly appreciated.
