Thanks for the great info CrewChief. It is flashing 6 times which I assume is a code.
g series machine will show a 4 digit code in the LH display while the code is active.
start machine,
seat bar down,
hit the PTO button.
when the idiot light starts to flash, DO NOT shut the key off, press and hold the light button down until the hour meter display changes and gives you a 4 digit numeric code.
once you key off, the code is cleared in the display, but is saved in the controller.
check the brake fuse and relay before you go too far.
the relays are all the same, you can swap a good known relay in it's place.
if the fuse is blown, you likely have a bad park brake solenoid.
you can check the resistance of the coils (red to black and white to black)
:drinkup
