Bobcat 610 charging problem
Virg1952
Wisconsin
I have a 610 with an internal regulator. New battery and wiring harness. It is backfeeding and draining my battery. It's overcharging. Does anyone have an ideas
Virgil
shane
Salt Lake City, Utah
Independent Field Service
You've got something hooked up wrong, somewhere, on your new harness install, or your alternator is bad.
I'd get a schematic and double-check all the connections.
geezer
st louis
You may need a diode in-line to one of your alternator terminals if it is a Delco with a internal regulator (terminal 1 or 2) I will look at mine tomorrow and tell you which one
