Best air grease gun and tips.
Discussion in 'Lubrication' started by auen1, Dec 17, 2016.
  1. auen1
    auen1 Well-Known Member
    Dec 17, 2016
    59
    USA
    That worked out GREAT!
    My job is getting easier and cleaner
    Thanks for the advice!
  2. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,617
    Service Manager
    Knoxville TN
    Good to hear it worked well for you. I've learned a few tricks in doing a lifetime of work. :drinkup
  3. curb guy
    curb guy Well-Known Member
    May 8, 2010
    172
    central ohio
    Glad I'm not the only one to use the Lock 'n Lube. Bought my first one somewhere, can't remember. The next day I called the place back and got 10 more. Worth every nickel!
  4. auen1
    Dec 17, 2016
    59
    USA
    Just an update.
    I put the locknlube coupler on our lube truck.
    I thought it was the best thing out there.
    We have 3 lubber guys, only 1 didn't like it.
    Anyhow the tip lasted about a week before the handle to lock it, broke.
    Before I had a chance to fix it,
    someone threw it away.
    I don't think I''ll be buying the company any more couplers......
  5. alb3rton
    alb3rton Member
    Feb 20, 2017
    10
    Fl
    You can't go wrong with lock-n lube tips. I'm very pleased how they work.
  6. auen1
    Dec 17, 2016
    59
    USA
    I get that some guys are rough on equipment, but a $30 grease coulper should last more than a week.
  7. DIYDAVE
    DIYDAVE Senior Member
    Feb 18, 2007
    486
    MD
    What I want know is what kind of neanderthal grease monkey can break a locknlube tip in a week, and still have his job?o_Oo_O
    mikebramel likes this.
  8. crane operator
    crane operator Senior Member
    Mar 27, 2009
    1,316
    sw missouri
    Ahha, watson, a clue: I've seen guys purposefully destroy stuff they don't like, then it disappears, so it doesn't come back around again.
    DoyleX and auen1 like this.
  9. Tenwheeler
    Tenwheeler Well-Known Member
    Dec 16, 2016
    80
    Georgia
    The Graco FireBall 425 is a good unit but I am not sure if that is a 50 or 80 to one. The 306-517 is a fifty to one rated for 160 psi air pressure and 8000 psi fluid pressure. The 306-554 is an eighty to one pump. It is rated for 80 psi air and 6400 lbs fluid pressure. Yes the higher ratio pump generates less pressure. They have about a 4 inch piston.
    The Alemite 7785 is a 40-1 pump. Rated at 200 psi air and 8000 psi grease pressure. The 7786 is a 75 to 1 pump with about a 6 inch piston. It is rated for 100 psi air pressure and 7500 fluid pressure. Volume is massive with it's 2" down tube. It's brother the 7795 is an 80 to one rated for 8,000 psi. The 8540 and 8541 are - were good 75-1 pumps with 3 inch piston rated at 7500 psi. I do not care for the PML and Ram pumps as much.
    The Lincoln 81685-83513 are a 2 1/2 piston 50-1 pump. They do a better job of picking up heavy grease than some other similar sized pumps. Have a low tolerance for trash in grease, require disassembly and clean out. I don't have their specs but the pressure rating is pretty high.
  10. Tenwheeler
    Dec 16, 2016
    80
    Georgia
    Looks like a flow control valve, Northern tool?
  11. GregsHD
    GregsHD Senior Member
    Sep 26, 2014
    360
    Self Employed HD Mechanic
    Mahood Falls, BC
    Anyone ever seen these locking tips? http://univer-co.net/en/products/lock-on-grease-coupler/
    Maybe only in canada, they sell like hot cakes at the local industrial supplier.
    I like them so far, very compact and simple.
    They make pressure release valves for grease guns as well.
  12. DIYDAVE
    Feb 18, 2007
    486
    MD
    Lock and lube appears to the the original, there's been numerous threads with it as the subject.:cool:
    How much does this version cost?
  13. Jonas302
    Jonas302 Senior Member
    Jan 4, 2015
    312
    mn
    they all made fun of my first lock and lube now the crew will not accept a gun without one
  14. GregsHD
    Sep 26, 2014
    360
    Mahood Falls, BC
    Paid $30 CAD for the univer-co coupler. Looks to be quality build unit. Will see how it lasts...
  15. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    500
    Field Service Tech
    Alberta
    I still use a pistol grip grease gun :(
  16. willie59
    Dec 21, 2008
    11,617
    Service Manager
    Knoxville TN
    Looks like a neat coupler GregsHD, many years ago I wondered why someone didn't come up with a grease coupler that works like an air line quick connect coupler, looks like that one does just that. I might just search it out and give it a try, but I'm sure happy with the Lock N Lube coupler. It's all about "building a better mouse trap".
  17. DIYDAVE
    Feb 18, 2007
    486
    MD
    looks like they're both about the same $ but the new one appears to be Canada only, per their dist map...
  18. mrappels
    mrappels Well-Known Member
    Nov 30, 2015
    56
    Diesel Plant Fitter
    Zimbabwe
    i know its a bit late, and i haven't had the pleasure of a genuine locknlube coupler, we did get a generic coupler with the same design. works great till the face seal tears or wears out. we went through 180kg of moly grease in 3-4 weeks, withpedal pumps. keeping the couplers clean was my pet peeve. it meant the difference between a week and two days.
    anyways, i stand by the H/duty coupler i came across from caterpillar. tough as nails and all metal, apat from one thick rubber seal inside. 10,000psi. lasted me months.
    for the life of me though i cant remember the part number off hand but will look for it and post it when i find it.
    Tenwheeler likes this.
  19. mrappels
    Nov 30, 2015
    56
    Diesel Plant Fitter
    Zimbabwe
    190-1670 - that's the one if i'm not mistaken.. has a steel insert, extremely durable.
    the 2M-2689 has a rubber insert, is smaller, but less durable and not really worth it.
  20. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    2,319
    IL. USA
