Did the Galion 402 use any other power plants other than international? Looks very similar to the Austin western 55. I've never seen a Galion from that era around here. Usually just Austin western, Trojan, caterpillar, allis Chalmers, and one lonely Minneapolis moline. I don't know if it's a power plant for something else or its own. The Galion looks like a neat machine.
markat, I am hoping someone on the forum knows the answer about other power plants used. I have not been able to find information about Galion 402. I only have about 50 hours working with mine but I really like playing. When I bought mine, the seller told me it was an Adams. It does look almost the same except the frame goes under the cab on the Adams and thru the cab on the Galion. The cab does not have much space inside because of the frame. See photo. They must have used interchangeable parts on many of these graders. The cab looks the same on the Austin Western, Adams, and Galion. The Adams also uses the international IU-4, the same as in my Galion 402. The cab really limited the view, especially out the back. One must really twist around to look out the back window. Since the cab was rusted away, I tore it off and wrapped plexiglass all the way around, and made a solid sheet for the front window and doors. Now I have 360 view! I started working on a slope meter Monday and finished it today. Very simple with 1 1/4" clear tubing and red ATF fluid. I mounted it on a board and secured it to the circle. My sidewalk is level, so I marked the position of the bubble with the blade down. I have a 10' blade and it was easy to figure the inches the blade would rise for each slope 1% to 8%. I raised the blade to each slope and marked the position of the bubble. I have not gotten to use it yet and it will probably need some more modifications. I used red antifreeze in the tube first, but it foamed and the bubbles would not dissipate and made the
position of the bubble hard to see. Then I filled the tube with red ATF fluid which made a nice bubble and flowed from side to side nicely. I may need to find a lighter color fluid so the bubble can be seen more clearly. I will post pictures so you can see the meter and the view from the cab.
