az350x
Hi-
First time poster here. I "inherited" an older Clark forklift, and I was wondering if anyone could help me decipher things like model year, etc. from the data plate?
It's a Clark C500Y180D with sideshift. Any idea what the "Y" and "D" in the model number indicate?
Serial number is Y1625-09-5570CB. It's rated for 18,000 lbs. I found and printed an Operator's Manual for the C500 Y 180 (and larger units), but while this manual gives info on LPG, CNG, gas and diesel-powered variants of this truck, the only diesel it mentions is a Cummins, and my unit has a Perkins.
My intention is to get it running and decide whether to keep it around or sell it. I know it's run within the last year, but I was told it needs a starter. I haven't touched it yet, but plan to drain/replace fuel, check fluids and coolant, charge battery, etc. before trying to get it running. I don't have a key for it, so will be needing to replace ignition switch also.
If anyone has any insight to any of the above questions, I'd sure appreciate it.
Thanks!
Tony
Thanks!
Tony
