980H rough Idle
Jonmiller
Michigan
Heavy Equip Tech
I have a 980H that ran great when we pulled the machine into the shop. We pulled the cab and replaced some hoses reinstalled the cab. Now we are experiencing every 10 seconds while idling the machine shuts off and turns then back on. We hooked up a laptop to the machine and at that the time it fires back up the machine throws a Status flag that says "Engine Overspeed". But our machine is just idling and not over speeding has any one had this issue or can help us get this machine running right? Prefix is JMS
Jonmiller
Michigan
Heavy Equip Tech
I have a Code 268-2 For engine parameters but i never did anything with that stuff
Try running a Product Status Report (PSR) from ET. It downloads as an Adobe pdf file. That might throw some light on it because it will show the Diagnostic Clock Hours for each ECM and the first and most recent occurence of each Code. Look for anything that is recent within the last 2-3 hours on the diagnostic clock.
When you say the machine shuts off, you mean that the engine shuts off as though the key had been turned off, right..? What happens at that point to the dashboard in the cab, does it die as well..?
Double check the Status Flag please. An "Engine Underspeed" status flag with the engine stopped would be normal.
Any chance of some photos or screen shots of what you see on ET..?
My suspicion is that during the reinstallation of the cab you have got a bad connection in one of the main wiring harness connectors.
Is the 268-02 Diagnostic Code Active or Logged..?
If it's Active it means that an ECM has detected that one or more of its programmable parameters have not been programmed (actually it says the data is "erratic, intermittent, or incorrect."). It is listed as a Diagnostic Code for the Powertrain ECM and the Implement ECM, but not for the engine strangely enough. It could also be caused by a less-than-perfect connection somewhere.
Go into the Configuration screen for each of those ECM's and look for a parameter whose status is indicated as "Not Programmed". (This could have been caused by disconnection of machine wiring harnesses)
If you need an Electrical Schematic shout out.........
mljohn
USA
are the parameters in configuration for FLT FLH settings blank?
Jonmiller
Michigan
Heavy Equip Tech
Yes as if the Key had been shutoff the only change on the dash is the warning light comes on and the coolant gauge sweeps. And it does say "Engine Over speed Shut Down" and "Cold mode" flashes. And what would you like screen shot or photos of?
mljohn
USA
save what config data you can and replace the ecm
I have seen this several times
Jonmiller
Michigan
Heavy Equip Tech
So maybe dumb question what is the FLT and FLH as im not very good with cats (mainly work on Komatsu Deeres and JCB's)
Jonmiller
Michigan
Heavy Equip Tech
Being that we are not A cat dealer do we need a Cat tech to come and flash this ECM??
Do you mean FLS & FTS..?
Good point - to the OP, go into the engine ECM with ET and on the Configuration screen check to see if there are numbers for the parameters FLS (Ful Load Fuel Fuel setting) and FTS (full torque fuel setting). They will be simply numbers (e.g. 12 & -52), but there should be something there in each box. Post a screen shot of the config screen.....
You don't need a Cat tech, at least not just yet you don't ............
mljohn
USA
yea fls fts got confused with some Harley Davidson flh flt sorry for any confusn
Another couple of thoughts having slept on it...... you had the cab off - has someone forgot to connect the cab electrical ground strap or does it have a bad contact..?
Also - was any welding work done on the machine whilst the cab was off..?
Mark250
victoria,Australia
heavy equipment technician
hi ,have you checked fuel supply pressure. possible squashed bent hose or pipe if fuel supply good do a visual check of all connectors and grounds if OK.
check power supply to ECM.using an LED test light check battery power to pin #48,52,and 53(red) of the ECM. use ECM pin #61,63 and 65 (black) as the return for the test light
if this is ok and the test light stays lit, check the key switch input to the ECM pin #70 (Orange) if the test light cycles between on and off check that no after market shut device is activating and causing the problem. also check your ground level shut down circuit has not been engaged
I Have come across a similar problem like this before. it appears you have access to ET. go into the status groups and monitor engine parameters, watch closely and obserb any cyclic changes across the parameters. if they are there they tend to average about 8 seconds between cycles this is too short a time frame for the ECM to log faults and usually means something is overloading the ECM internal circuit protection.this can be either internal or external to The ECM.
the easiest way is to use a test ECM and temporarily connect to engine and try. or you can isolate circuits one by one at the ECM and try and isolate by elimination
if you find that the ECM is faulty use the ET function to copy the config files which will record most of your settings including injector trim files. however you will still need to do a timing calibration once you fit the new Ecm
usually if the ECM is that far gone the copy config file part of ET wont work .if that is the case you need to manually do a product status report if possible and re enter the settings by hand. you may have to remove the rocker covers and record the injector serial numbers and obtain trim files from sis in really bad cases
Mark250
victoria,Australia
The JMS prefix funs a C15 which will use injector trim codes the C-15 uses a four digit trim code stamped on the injector
