Willie B
What are you calling pretty hot? Have you checked the temp with a thermometer, I'd like to know what temp your transaxle is running. And BTW what model is your backhoe where is four speed shift lever?
I have not measured it with a thermometer. Tractor is 1988? model 580K with four speed coming out of the floor at right front of floor. It being torque converter equipped, it slips some in high gear climbing. 16000 plus pounds won't climb hills easily with seventy horsepower. The book says extend a hoe sdds 2050 pounds, the cab adds 600 lbs. I have a hydraulis thumb, adding more weight. I use third gear on steeper hills.
Willie
Willie
